Also available for $11,000 with No electronics
Above Added: Mon May 14, 2012, 8:18 pm EST 85 Chevy S10 Round tube back halved by Wild Rides located in NJ WWW.WildRidesRacecars.com This Car is a real Money Maker has won every type of racing from Big Dollar Foot Brake races to Super Pro to NHRA Super Street hate to see it go but I have a new project in mind Chassis: Chromoly Round tube Back half 4 Link with Anti Roll bar Fab 9 Rear strange Center section Spool and axles Wilwood Brakes on all 4 Wheels Has 14X32W on Rear Hoosier Fronts On weld Aluma stars Lowered spindles, Moroso trick springs Qa1 adjustable fronts QA1 rear adjustable Coil overs Set up with Motor plate for Small block Chevy and Powerglide Dual battery Mounts with 2 Yellow top Optimas 5 Gal Fuel Cell with all Black Braided Lines and Fittings -12 to filter -10 to front with -8 return line -4 Trans lines all match Body: Body work and Paint done At Thriftway auto Body WWW.ThriftwayAutobody.com can be seen in customers section Quarters stretched to accomodate Changing big Tires Cowl Hood Bed is finished inside stock bed floor completely removed and done beautifully in Sheet metal and tinned on top painted Silver with a removable section to access batteries and fuel Cell also has access flap to fuel between rounds Interior: Stock floor replaced with Sheetmetl and Extra Large tunnel for Trans Clearance 2 Kirkey Seats with Covers Hurts Quarter stick with elec shift Solenoid 5Pt Harness Removable Window net 8.50 Cert Cage cert expired with drivers side swing out Bar Carpeted interior with Custom dash Electronics: MSD digital 7 Programable Biondo mega Switch Panel with circuit Board Biondo Elec shift controller Biondo mega 450 with custom removable mount wired with weather pack connectors 2 Biondo Double 0 Buttons in grant tilt wheel http://http://www.racingjunk.com/Spo...half-S10-.html |
