Old 06-01-2012, 04:20 PM   #1
Shane Studley
Liked 2 Times in 1 Post
Default 1999 Dodge Dakota GT/TB (New Lower Price)
GT/TB Record Holder 9.82 @ 132.82 with 360 small block. This truck was built by Phil Mandella of PMR Race Cars and debut the 1999 Winternational and won Best Engineered. This Truck was also # 1 qualifier at the 2000 U.S. Nationals in Super Stock and most recent # 1 qualifier at the 2009 Winternationals and also WON the eliminator at the 2009 Winternationals. This truck will win "CLASS" anywhere in the county and is a proven National Event Winner. This truck Has the absolute best of everything and is completely science out. Many spare parts go with the truck.
The chassis was built on a jig by Phil Mandella and is built using all chromolly tubing with a funny car cage.
Lamb components 4 wheel disc brakes that have been all freshened in 2009
Ford 9 inch rear end MW heavy duty aluminum third member with new back cut rear gears and scalloped steel spool in 2008 set up by Lamb components
40 spline and gun drilled MW axles
Rear shocks are Koni coil over from Lamb components and Dyno tuned by Roger Lamb
New fuel system and replaced all hose in 2009
New aluminum radiator in 2009
New CSR water pump in 2009
New MSD Digital programmable ignition system
New front tires with 1 new spare tire and wheel in 2009
New Rear Tires And 2 Spare tires and wheels
1-2 & 2-3 Air Shifter
(Dave Smith) PRO TRANS ROLLERIZED 904 ALL ALUMINUM FRONT & REAR DRUM WITH TRANS BRAKE
Munsinger 8 inch Torque converter
3 gallon fuel cell
custom aluminum bed cover
Custom OIL PAN from Billet Fabrication
Custom headers from Dawson Headers and ceramic coated with O2 sensors in each tube
Mark Williams Removable steering wheel
Custom Drive Shaft from Inland Empire Drive line with new u-joint in 2009
This truck has been maintained meticulously and is in as new condition.
$32,500 T/K. OBO
Call Shane Studley @ 714-401-7405 for pics go to www.autoimagery.com and type in my name.
Shane Studley is offline   Reply With Quote
