Old 05-30-2012, 08:09 PM   #1
aspen7709
Default msd coils: HVH vs Pro Power pros and cons?? better one?
Which coil is best and why? Double the price for the HVH. Why? I have used the pro power for years. Pros and cons to either?
Kenny 7709 ?/sa
aspen7709 is offline   Reply With Quote
Old 05-30-2012, 08:29 PM   #2
GTX JOHN
Liked 2,487 Times in 698 Posts
Default Re: msd coils: HVH vs Pro Power pros and cons?? better one?
We run HVC on all our cars. Seem to last better and perform better.
Had to take two degrees timing out compared to Pro Coil. No clue why
but did.
When do we find out you new car combo? ..... Inquiring minds want to
know.
Good Luck!
Irving Family Racing
Old 06-05-2012, 09:31 AM   #3
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Is this always the case or will it vary for different combinations.
Originally Posted by Techwest Racing Services View Post
GTX JOHN
The MSD HVC coils are a faster reacting coil than the Pro Power 8201 coil. The retarding of timing is a side benefit of the HVC coil, less timing in the engine with better performance.
MEXJOE is offline   Reply With Quote
Old 06-05-2012, 01:03 PM   #4
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Pat, I am using a 7al-2 with a 8201 coil, but I also have a 8261 coil. Would I be better off using the 8261 coil? I have two of the 7al-2's and both of them are probably 10 years old. Are there any performance gains if I had you do any upgrades to these boxes? I cant say that I feel like anything is wrong with the box I'm running, and the other one wasn't having any problems last time I used it.
Thanks, Chuck
C and W Racing is offline   Reply With Quote
Old 06-05-2012, 01:18 PM   #5
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Pat,
Would this also be the case with a 6-series ignition (#6421) and the HVC-2 coil (#8253)? The output information on the MSD website suggest this is an acceptable combination.
Thanks!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-05-2012, 02:27 PM   #6
MEXJOE
MEXJOE's Avatar
I guess what I was asking was, Rather than the combo of MSD components...
Would you see a difference for a specific engine combo due to combustion chamber style shape etc.
Or will you automatically need to lower your timing 2 deg. with this coil
Here is my situation.
I did not dyno with my MSD setup THAT IS IN MY CAR.
THE MSD ON THE DYNO USED A 7AL2 AND A PRO POWER COIL.
I have the 6AL and the 8252 coil in my car.
Thanks
MEXJOE
Short answer combo does not matter. If you hook up the box & coil on the bench with an oscilliscope. Then vary the sparkplug gap from narrow to very large you would find that the MSD 8251 coil is very fast reacting coil when compared to the MSD 8201 coil. We repeated this same kind of testing over the past couple of years during dyno testing. The results were the same the MSD 8251 coil was a better match to the 7 series boxes. Thanks for the great question!
Old 06-06-2012, 11:17 AM   #7
Lew Silverman
Lew Silverman
Yes, the MSD 8253 is a good match up to the MSD 6421. Many of our customers use that combo in their racing program with good results.
Thanks, Pat!
Lew Silverman #2070
Old 06-06-2012, 04:37 PM   #8
MEXJOE
MEXJOE's Avatar
Thanks!
I'll see if we can use our stuff on the dyno next time.
MEXJOE
Ok, now we are on the same page! Let me start with, as a common practice when using Dyno time to dial things in. Consider bringing and using your ignition setup to tweak things in. The two setups you mentioned should provide different results if your there to tweak the engine in. If your there to just see what numbers the engine can pull then just run what they have hooked to the dyno. As for moving the timing, each engine has its own personality and will have its own sweet spot. Most of our customers find that they only need to move one degree of timing when tweaking things in.
Old 06-07-2012, 08:11 AM   #9
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Techwest Racing Services updated my MSD and its works "GREAT". Thanks Pat............They have thier Sh**t together.
Bob Bender 144 O/SA
