Old 05-21-2012, 08:59 AM   #1
TS310C
Default Random slow reaction times!
I recently figured out that after 4 runs on my car (almost exactly) in one day I get a reaction time around .050-.060 after being in the .000-.015 range the previous runs. At first I just figured I was missing the tree, but the more it happened, the more I realized this can't be a coincidence. This weekend I went red the first two hits, then loaded the box and went .015. On the fourth run (same lane, same delay setting) I went .068! It did this on both Saturday and Sunday of this past weekend. After looking back through my log book, it has done this at the last 6 races dating back to last season! I have to believe it is a heat related thing since it happens on the 4th run of the day. Could it be the transbrake solenoid? I was thinking delay box, but I don't know why it would happen after 4 runs ever time. Any help is appreciated!
Thanks!
Ryan Koener
S/G 310C
TS310C is offline   Reply With Quote
Old 05-21-2012, 09:28 AM   #2
Bill Baer
Default Re: Random slow reaction times!
Ryan
The problem could be heat soak in the solenoid but it could be electrical ,we added a "Stop it" from shogun and ran the ground wire directly to the battery and that seemed to help considerably.
Or you could just count on luck to provide you with a( little rusty) old fart opponent who put's out the top bulb. LOL
Old 05-21-2012, 02:39 PM   #3
TS310C
Bill,
I just got lucky against you! I'll take a freebie whenever I can get one. As always I had a great time racing with you guys! The car was dialed this weekend, just need to get the reaction time deal figured out.
I have talked to Hughes (trans) and K&R (delay box). They both said they don't think it is their product and they both have good points about why not. I am sending in the box to have them look it over just in case. Kevin from K&R also wants me to replace my transbrake button. He says they tested every button on the market and the big red B&M button is the best. Not sure why that would change after 4 runs, but I am going to try whatever I can. I might even change transmissions just in case. Ideally I would change one thing at a time so I knew what did it, but I don't have that luxury. I don't want to waste a race each time I find out it wasn't fixed.
Ryan Koener
S/G 310C
Old 05-21-2012, 02:57 PM   #4
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Ryan, I had the exact same thing happen to me this past weekend. Made a time run in each lane and was .018 in both lanes. Took .006 out of the box and first round I was .027 but thought I may have missed it some. Next round I was .050 and thought I drilled it. Next round I was .027 again. Lost that round. Sunday I was going to check my solenoid before our one time run. It was dragging when I pushed it in and I felt that was my problem. Made a time run before I changed it because they called us to the lanes before I could. I was .053 on the tree, came back and changed the solenoid and was .013 first round. From the 2 time runs the day before, you can see I was set up for a .012 so I feel like that fixed my problem. I'm .013 and take .003 stripe and break out to a .007 dead on 1. lol I also have the shogun stop it on my car.
Chuck
C and W Racing is offline   Reply With Quote
Old 05-21-2012, 03:05 PM   #5
TS310C
Chuck,
I am thinking that I may change the solenoid even though Hughes doesn't think it is the problem. I just want to make sure I have everything covered. We don't get out as much as we used to and if I am spending the money to race I want to make sure it is fixed.
I am sending the box to K&R tomorrow and picking up a new button today.
Ryan Koener
S/G 310C
Old 10-06-2020, 08:25 PM   #6
sgasman
Liked 10 Times in 6 Posts
Originally Posted by TS310C View Post
Chuck,
I had the exact same thing happen I even put my buddy in the seat for 2 passes. No luck turns out I changed the solenoid and back to normal. I change solenoid every 2 years now
sgasman is offline   Reply With Quote
Old 05-21-2012, 05:57 PM   #7
Brian Hansbury
Brian Hansbury's Avatar
Send a message via Yahoo to Brian Hansbury
I Feel Your pain i had the same issue was told convertor sprague broke bought a new convertor and thought i was good went .018 but second shot was .061 though i really missed it so left it alone for fisrt round went .060 can u say duck .....changed solonoid this weekend and was .032 took ten out went .017 took ten out went .003 so rolled it ou sunday all was good lost second round took too much stripe like a D--K oh well good luck
Brian Hansbury is offline   Reply With Quote
Old 05-22-2012, 05:38 PM   #8
Rick Bailey
Rick Bailey's Avatar
Liked 10 Times in 7 Posts
Old age Ryan........... old age !
Rick Bailey 3439 SC
Rick Bailey is offline   Reply With Quote
Old 09-27-2012, 04:16 PM   #9
BigWayde
So did you guys ever figure out the cause of the poor reaction times?
I have the exact same problem with my car right now. .006 and .014 in time runs then in first or second round I'll go .035 or .040. I don't feel like I'm missing the tree at all. We've changed transbrake solenoids but we are still having the same issues. I have a new delay box on the way.
Just wondering if anyone figured it out yet!
Thanks guys.
BigWayde is offline   Reply With Quote
Old 09-27-2012, 05:39 PM   #10
Bill Baer
Try checking or adding a ground to the solenoid (cheap & easy)
