Old 05-13-2012, 08:49 PM   #1
rich freitag
Smile wanted AVS carb
HI, anyone have a AVS carb for a super stocker, 70-71 mopar please let me know , motor is a 383 i need the smaller carb ,I like the ones with two mixture screws like the #4966 I don't need any cores ,I need a carb that works ,call 315-452-1255 RICH FREITAG
Rich Freitag 1440 SS
rich freitag is offline   Reply With Quote
Old 05-13-2012, 09:54 PM   #2
GTX JOHN
Default Re: wanted AVS carb
Could you possibly be a little more specific.........Different engines had different
sizes and different booster tabs. I own about a hundred and they are fairly simple to modify
for racing. If you want the absolute best.....Steve Wann is the best one to build it! IMO
I sell good cores for $100.00 forany Part # and can tell you enough to get you pretty close
on Mods.
Old 05-14-2012, 01:13 AM   #3
Phillip marvetz
Phillip marvetz's Avatar
Hey John, How much slower will a AVS be VS a Thermoquad?
2009 V/SA Record Holder
Old 05-14-2012, 05:47 PM   #4
GTX JOHN
on your 340 about .15 - .20 on the stock intake manifolds......given the same weight AND well prepared AVS (Like Steve's Carb.) less on 440 that can run larger 750 (1 11/16 primaries ) AVS maybe .10.
See you in a couple months!
WARNING: If you have let me work on your AVS the difference will be much Worse!
