Old 04-26-2012, 08:47 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default 12 bolt yoke
Can you tell me what needs to be done to a 12 bolt OEM yoke to put a logger sensor on it?
Ron Gusack is offline   Reply With Quote
Old 04-26-2012, 10:18 AM   #2
440lebaron
Default Re: 12 bolt yoke
i think the only tone ring you can buy are for 9", i glued my magnets to the ujoint caps
440lebaron is offline   Reply With Quote
Old 04-26-2012, 10:35 AM   #3
Dion Hildebrandt
Dion Hildebrandt's Avatar
Get a mark williams yoke.....joking.On the stock one I removed the dust ring in front of the seal and had to do some minor grinding ,computech had the appropriate sensor ring and your off to the races
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 04-26-2012, 12:38 PM   #4
Ron Gusack
Ron Gusack's Avatar
Thanks for the info, I have a ring from Racepak and I would like to not have to take the yoke off the rear to install it.
Old 04-26-2012, 02:06 PM   #5
Dion Hildebrandt
if your careful you can do the modification to the yoke on the car ,I did it on the car for the same reasons
Old 04-26-2012, 04:21 PM   #6
Ron Gusack
Ron Gusack's Avatar
What did you use to grind? A sharp flat file, Dremel, or a die grinder maybe? I'm thinking I have to pretty precise to keep the collar true.
Old 04-26-2012, 04:31 PM   #7
Dion Hildebrandt
Believe it or not an electric grinder and a fine touch. all that has to happen is the four square corners need to be rounded out equally and a lot of grind, fit, grind, fit, etc.
Old 04-26-2012, 05:58 PM   #8
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
Smile Re: 12 bolt yoke
Dion, your collar must have been a different width as I couldn't find a way to fit the racepac collar on my yoke without a lot of interference. Mark Williams didn't make a 12 bolt yoke with the clearance machined and woudn't make one. So I had strange machine a chromemoly yoke. Looked cool, and so did the blue print . I made a mount to bolt onto the center section webbing to mount the pickup.
But then, maybe your are just that much more accurate with a grinder than I am .
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 04-26-2012, 10:00 PM   #9
james schaechter
Liked 1,438 Times in 301 Posts
I have a Mark Williams yoke ( for 1350 u joints) and a 12 bolt and the collar bolted right up. I don't remember the part number, but it was an off the shelf item.
James Schaechter 3163 STK
Old 04-26-2012, 10:53 PM   #10
Dion Hildebrandt
Mike I use a computech datalogger and possibly the collar for the yoke is narrower as it didnt take much grinding to get it to fit. I now have a Mark Williams 1350 yoke and the collar just fit right up no mods neccessary. Also my job includes a lot of power tools and precision contol
