Old 04-24-2012, 03:51 PM   #1
mishsc
Default Parts for sale
3919840 BBC. heads.Dated A-11-8 and A-12-8.No port work done.Completely stock.These are bare castings,no valves $1500
2spd. powerglide and converter.Traded for this and never used.Was told it was set up for drag racing and used in a '55 chevy. $600
9in. ford rear end minus brakes.441/2" from housing end to housing end.4.86 richmond pro gear.Spool.Nodular center section with billet yoke.Was in a '69 camaro leaf spring car.$1,000
427 BBC .060 2 groove Ross pistons and Childs and Albert rods and Lunati steel crank.$1200
Used QA-1 single adjustable rear shocks.Number stamped in the shock is 866501.In great shape.Weren't on the car long.$225
Used MSD distributor part #8361 and Blaster2 coil.Needs cap.$125
Used BBC Comp #948 valve springs.(2 sets)$75 ea.
Used side and rear glass for '69 camaro. Good shape.$100
Used '69 camaro rear bumperettes.Good shape.$25
Barry Grant fuel pressure regulator w/gauge$50
Joe Gibbs XP-2 (7 qts.)$120
Joe Gibbs Break in oil(1 qt.)$10
1 Case Valvoline VR-1 10w30 $50
14 qts. Exxon superflo 10w30 $50
6 qts. Lucas racing oil 20w50 $40
7 qts. Castrol type F transmission fluid. $20
Chrome BBC thermostat housing. $10
1 K&N oil filter #3002 $5
Make me an offer.Any shipping will be buyers responsibility.Let me know if you have any questions.Thanks.
Shane 502-727-9909
mishsc is offline   Reply With Quote
