A small block chev gasket 40 thou thick,how much will it compress to?
Liked 1,868 Times in 422 Posts
A Cometic gasket will only compress to the thickness of the individual pieces. Usually you have a 0.020" stainless piece in the center, and then two coated pieces riveted to it. Measure the unembossed thickness of the two coated pieces, and add that to the 0.020" stainless piece in the center, that's your minimum compressed thickness.
Alan Roehrich 212A G/S |
Liked 30 Times in 17 Posts
Lonnie,
You can call them to verify it, but as far as I know, the thickness listed is the compressed thickness. In other words if the gasket part number ends with -40, it will be .040 compressed thickness.
Bill Koustenis |
Liked 2 Times in 2 Posts
I think they give you the compressed thickness and the cc's.
