Old 04-16-2012, 05:13 AM   #1
Greg Barsamian
Liked 427 Times in 97 Posts
Default 355ci Chevy Engine
.010- Gm4-bolt Main Block
Forged Steel Crank
Fluidamper Harmonic Balancer
.030 Over Keith Black pistons 11.9 compression
GM Lt-1 Rods w/ARP A2000 Rod Bolts
Comp Cams Solid Lifter camshaft
562 lift intake / 557 lift exhaust / 106 lobe centerline
Mellings "High Volume" Oil Pump, Moroso Pan/Pick-up
Air-Flow Research Ported Aluminum Heads 210cc
w/ Air-Flow Research Port-matched Intake manifold
MSD distributor w/ wires
Crane 1.5 Gold Roller Rockers w/ Stud Girdle
Balanced Assembly
Best ET in 3500lb 4-Speed Chevelle 11.48 @116mph
Complete less carb $3500.00 + the ride
Contact: gwrench2005@hotmail.com,
or (508) 769-7867
