Old 04-14-2012, 12:25 PM   #1
KEVIN T
Default Timing?
Hello all, Perhaps someone knows of or has expierenced this. I set the MSD crank trigger to 35 degrees but when I check it with a timing light it is only at 32 degrees. I checked to make sure that the damper it true @ TDC and it is. So is there a, + or - in the MSD box? I wouldn't think so. Any ideas?
Thanks,
Kevin T
KEVIN T is offline   Reply With Quote
