Old 04-12-2012, 09:30 PM   #1
slwryde
slwryde's Avatar
Default gear or converter
My car is a little lazy of the line. I have a 414 sbc. 1.76 powerglide. 14-32 slicks. Rear gear 5.13. 60 foot times range 1.52 to1.55. My converter stalls instantly to 4500 on the brake and creeps up to about 5000.
Again it leaves lazy, I think. I would like opinions on weather a rear gear change (deeper), a converter change (looser) or a lower tranny gear would be best.
thanks Greg.
slwryde is offline   Reply With Quote
Old 04-12-2012, 09:45 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: gear or converter
reply deleted following the op's comment.
Old 04-12-2012, 10:03 PM   #3
slwryde
slwryde's Avatar
The camshaft is 255@050 int and exh. .575 lift on both
The carb is a 850 holley
Engine is 9 to 1
Dyno 575 hp@6900 and 535ft.lb@5300
Old 04-12-2012, 10:21 PM   #4
1320racer
1320racer's Avatar
reply deleted
Old 04-12-2012, 10:26 PM   #5
slwryde
slwryde's Avatar
like you
Old 04-13-2012, 12:22 AM   #6
Geerhead55
Liked 5 Times in 5 Posts
Angry Re: gear or converter
Originally Posted by slwryde View Post
like you
WTF does that mean, Greg? This guys trying to help you and you bash him. Your motor is light on compression,, your camshaft is on the small side for a stroker small block, your converter is a little tight, and you come on here asking for help and you blow somebody off when they respond to your question. So much for getting any help here, I'm thinking.
Good luck with your project which ever way you decide to go.
Danny Durham
Old 04-13-2012, 01:28 AM   #7
rustbucket79
thanks Greg.
I choose option 4, all of the above. A 3 speed trans would probably make the most difference if you're only changing one thing.
rustbucket79 is offline   Reply With Quote
Old 04-13-2012, 08:51 AM   #8
slwryde
slwryde's Avatar
Danny Durham
It means take the time to explain yourself...like you did. Your input is helpful. You think the camshaft is small for a stroker small block. 1320 said it had to much duration. Also you think the converter is to tight.
Another guy said a three speed might be best.
The engine makes good power and torque despite the low compression. Its easier to change gears and converters than camshafts and compression.
So which would benefit most gears or the converter?
Old 04-13-2012, 11:55 AM   #9
Phillip marvetz
Phillip marvetz's Avatar
Lower 1st gear would be my choice. What RPM are you running thru the traps and is it where you want it to be?
2009 V/SA Record Holder
Old 04-13-2012, 12:34 PM   #10
slwryde
slwryde's Avatar
I am turning 6900 rpm. I could probably afford to turn it a little higher say 7500 rpm.
