View Poll Results: How should a revamped AHFS work?
Leave it alone 5 17.24%
Drop the 1 second under 'flag' at LODRS and Nat'ls 4 13.79%
Drop the 1 second under 'flag' at LODRS only 2 6.90%
Adjust the automatic point to -1.25 3 10.34%
Adjust the automatic point to -1.15 5 17.24%
If setting/going for a record, you're exempt from a hit/flag 9 31.03%
You must pass teardown before automatic hit is assessed for -1.20 18 62.07%
Multiple Choice Poll. Voters: 29. You may not vote on this poll
Old 04-05-2012, 07:50 PM   #1
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default AHFS syetem (sample poll, for Ed F)
Just a sort-of fake poll. You may choose more than one option. I really only did this for Ed Fernandez, to show you can post a poll, with anywhere from four to ten options, when you start a new thread.
I voted for 2 (accidentally, keep the -1.00 at Nat'ls only), 3 and 7. I think it's wrong that someone can get a combination hit and is never checked (torn down) to insure legality. Drop the -1.00 'flags' at LODRS (keep the -1.20 auto hit). If the rule was changed that 'if you attempt and/or set a record, you are exempt from HP, half the field could/would put an 'R' on their window, so I would not vote for that.
Anyways, have fun with the poll. If you vote for more than one, feel free to share which one(s). The results will probably be skewed with multiple votes allowed, it's more of a what-if, for-fun type thing.
Old 04-05-2012, 08:56 PM   #2
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: AHFS syetem (sample poll, for Ed F)
Thank you Mike.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 04-05-2012, 09:18 PM   #3
Mike Carr
Mike Carr's Avatar
No problem Ed. How is post-racing life so far? Any street/strip or cruising 'toys' in the works?
Actually, the more I think about it, I do think that records runs should be exempt from the AHFS. Though some may use it as a loophole, a good number of racers pride themselves on the performance of their cars...Class Wins, Records, Qualifying #1 (you know, things that seperate us from normal bracket racing), etc. If you're going to choke us down into setting a record, on the brakes, at -.999, or -1.199 under, it greatly dilutes the time honored tradition of records.
Old 04-07-2012, 03:32 AM   #4
Ed Fernandez
I'm slightly looking Mike.
92 to go
Former NHRA #1945
Former IHRA #1945
T/SA
Old 04-07-2012, 06:42 PM   #5
Toby Lang
Liked 2 Times in 1 Post
Originally Posted by Ed Fernandez View Post
92 to go
He didn't actually delete all the posts in the lounge. They are still there. He just created a new section. If he does actually delete all the posts in the old lounge, your post count might take a little hit.
-Toby
Old 04-07-2012, 07:20 PM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
-Toby
where?
Old 04-07-2012, 07:22 PM   #7
Toby Lang
Originally Posted by Tom keedle View Post
where?
http://classracer.com/classforum/forumdisplay.php?f=21
-Toby
