Jesel Pro Series Rocker Arms for a SBC
-Brand New, individually wrapped in the box -Intake part # IRR-01001, number on rocker BABR80 -Exhaust part #ERA-01001, number on rocker BAAS70 -$900 Manley Rods for a BBC - Used -"H" Beam Rods -Part# 14062-8 -Center to Center 6.385" $200 Be Cool aluminum radiator w/ fan -fits Firebirds/Camaros. -$500 1050 Bob Book Carb for Sale -Gas Carb -Rebuilt Spring 2011 -Great Condition -$950 400 SBC For Sale -done by Brian Tilburg Engines -632 HP -Approx. 40 runs. -Ran 9.93 at 3250 lbs in a 2000 Pontiac Firebird -MSD belt drive distributor -ATI dampener -Danny Ashley Quadra-Jet -Ran in NHRA GT Super Stock class but can be used in other classes. Last freshened in June 2011. -Updated cylinder heads -new Crower lifters -new Jesel rocker arms with roller tips -new 50 mm camshaft -new Manley valve springs -new Pac retainers -new valve locks/lash caps -new exhaust valves Asking $12,500. We just put $8,000 in to have it freshened. It is a very reliable motor in great condition! Trans Specialties Converter for TH350 -6000 stall -$400 Wilwood 3/4" master cylinder Part #260-1304 Asking $40.00 Aluminum CSR Oil Catch Can -$75.00 MSD Ignition 8735 MSD Launch Control Module Selector -Brand new in the box. -$150.00 Barry Grant Paper Fuel Filter Replacement for Gas engines -Brand new in wrapping. -Asking $15.00 Barry Grant Wire Mesh Fuel Filter Replacement for Alcohol/Methanol engines -Brand new in wrapping. -Asking $20.00 Barry Grant Inline Fuel Filter -Brand new in box. -$100.00 Chrome Aerospace Components Oil Breather Tank -$125.00 Chrome Mechanical Fuel Pump Bracket -$50.00 Digital Delay Digital Viewer -$150 http://www.racedigitaldelay.com/delay-digviewer.html Rossler Trans 2.27 gear ratio steel internals powerglide input shaft reverse pattern with clean neutral transbrake. This is a Rossler trans freshened by Coan. I have not made any passes on it since we had it freshened. All new below from Coan: standard pump assembly sungear/output bushing pan gasket pump to case gasket TH350 pump to case o-ring direct pressure plate pump shim clean neutral valve body kit standard brake -$2500 Pictures or questions please e-mail splingaire4@gmail.com. |
hi do u no rocker ratio for exhaust and intake and do they have shafts and bolts thx
The rockers have the shafts but no bolts.
The ratios are 1.80 and 1.70. The last two digits on the rocker arms are 80 and 70. Those denote the ratio. If you PM me your e-mail I can send you a Jesel Rocker Arm code chart and a picture of one set of the rockers. |
