hi! i have not raced in 15+ years
![]() ![]() i found a stock suspension 1967 camaro with a fiberglass front cap,that i am building for my son (and i get to get in till he is old enough ![]() 12 &1/2 to 1- 355 small block , th350, 8inch converter( the 1st owner said 5300 stall ![]() looking to see what size rear tire should i run (30x9?) i really don't want his 1st car to leave as high as you guys ![]() thanks for any imput at all (good or bad) ![]() |
#2 | |
Liked 2 Times in 2 Posts
To be consistant you need to hook... The wheelstands can be controled with shocks in the front generally speaking. Or wheelie bars if needed. How big a tie will ft under the car? What rpm are you wanting to trap at?
Tod Lane Swartz & Lane 66 Nova Swartz & Lane 79 H/CM Trans Am |
#3 | |
someone said with the caltracks you can adjust how high it comes up, personaly i dont have a clue , just looking for answers, and to see how other people set there cars up i posted this to see what size tires to put on the car , i was thinking 30x9 but i really dont know if that would fit. i just dont want my son to leave with the wheels 2 to 3 feet in the air , i have seen some trans blankets from the fence and though its pretty i dont think a new driver (no seat time) should start that high |
Talk to these guys................
Scott Helms sales@southlandspeed.com parts@southlandspeed.com 3729 West Park Avenue Gray, LA 70359 (985) 580-9701 or Toll Free 866-580-RACE (7223) Fax (985) 580-9705 |
thanks mr. steve, i have talked to scott alittle about the car ( he wanted to buy it lol) and i talked to kevin alittle. i was just trying to get some ideas, i think 30x9 will fit looks like it will be close
Liked 93 Times in 52 Posts
Measure and then re-measure to ensure your rear end is PERFECTLY centered in the rear wheel opening, or I'm not sure that you will be able to fit a 30x9. If you do have room for a 30x9, it will need to be a radial slick. A bias slick will grow.
I had one Hoosier 30x9 radial mounted on my spare Weld wheel. It fit on one side, but not the other. When we replaced the rear end, we had to move the center pin locating hole to square up the rear in my car. I now have the 29x9 bias Hoosier on mine with a 15x8 wheel with 4.75 backspace (.25 spacer). ![]() Clark |
thanks cad thats what i was looking for thanks for repling to my thread,
i didnt want to buy a set of tires new to set up the car, by the way your car looks awesome!! |
#8 | |
Grant |
thanks grant,
some is suppost to bring me some used hoosier 30x9 radials tonight to try, i will mount them and check center. i really hope they fit |
Good to see a parent getting back in a car (even if just for a while) and keeping our kids in the sport! Here are some suggestions to get a simple but consistant car back together, without breaking the bank. Make the car work, even if not the fastest for now, and it will be more fun to race and learn with... Not having to fight a dial in is worth a lot!
As you are just trying to get this thing back running, and it will be a bracket car, I would look at the Mickey bias tires. Lots of sizes out there, cheaper than radials, last much longer, and will hook better on a lose track or with a suspension that is not maxed yet... Lot of people run the 10.5x28 on an 8" rim, with 4.5 back space. Wheels are easy to find used, will fit without having to "exact measure" the rear end in the wheel well, etc. I have a 67 Firebird stocker, and I have radials, different wheels, etc. While for stock it is pretty much a requirement, for bracket racing, no so much. I recommend the Caltrac's. Call them, and they can set you up with a good package that will last. Their bars, rancho rear shocks, and their front shocks will make your "stock" suspension work well. Again, lets make the car consistent, and hook. Calvert has great tech support, along with a ton of racers on here that will help. They do have adjustments to keep the car down, it is starts wheel standing. Best part, no matter how hard you want to run it later, the Caltrac setup will grow with you... some of the fastest stockers and a few super stockers in the country are running their stuff. One other suggestion for now. Put a glide in it instead of the th350. One less gear change to worry about. Will make the car leave a little easier too. If you use a turbo input, you can use the same converter, and its same overall length, so just change yoke on your drive shaft and you are good. Again, can do this stuff without breaking the bank, and have a much easier to drive and consistent car. Good luck and let us know how it goes! |
