Old 02-22-2012, 01:01 PM   #1
vetteboy
Liked 2 Times in 2 Posts
Default Quick time bell housing question.
I have a quick time bell housing and have problems getting it parallel to the block. I have .004 run out right know, is that close enough? I have had the bell housing ground flat. Do you guys then shim the bell housing to the block or do you somehow machine the block perpendicular to the crankshaft. Thank Brett
vetteboy is offline   Reply With Quote
