Old 02-06-2012, 11:33 AM   #1
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Oil pump pickup - tack weld or don't weld
We've just finished a complete refresh on my small block chevy.
Late last summer, we began having a few oil pressure anomalies. When we tore it down, we discovered the Milodon screen/box broke off of the end of the tube.
I froze and then installed the new Milodon pick up tube assm in the M55HV. I got it "seated" completely into the pump, put it back together, and then had to rotate it slightly to get the pan clearance.
Milodon said do not weld the tube to the pump and they also recommended their "extreme duty" pick up 18316.
What is the concensus?
Should the pick up be tack welded to the pump?
Thanks,
Clark Doukas
