I've just measured my motor. And would like to see what compression ratio others come up with?
Here are my specs. Bore 3.480 Stroke 3.976 Flat of piston is .010 out of the bore Head volume 49 cc Head gasket thickness .077 Head gasket bore 3.50 Volume of cylinder with piston .355 down the bore is 47 cc I believe that will give me a dome volume of 8.33 cc's Head gasket volume is 12.14 cc's Cylinder volume is 619.7 cc's
Art Leong 2095 SS Last edited by art leong; 01-17-2012 at 01:10 AM. |
Sorry meant to post this in the tech section.
I've used some of the online calculators and I get some quite different answers. Numbers vary from 11.7 to 1 to 13.0 to 1
Art Leong 2095 SS Last edited by art leong; 01-17-2012 at 01:23 AM. |
Liked 2 Times in 2 Posts
Art. My compression ratio program useing your info. Say's it's 13.1:1 normally aspirated at sea level. I also get the same cylinder volume as you do 619.7 cc's.....hope this helps.....norm
Using the compression ratio calculator on my copy of Larry Meaux's PipeMax software, I get 13:1.
Alan Roehrich 212A G/S |
Google compression ratio calculator. A nice site comes up with a number of different tools.
Art, you should buy Pipemax. Very usefull.
Ed Wright 4156 SS/JA |
