Old 12-30-2011, 11:45 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default BBC Square Port Heads, Intakes, Blocks & Parts
1966 427 4 bolt standard bore 3869942 with original pistons & rods $4500
1967 3919840 square port heads rebuilt and ported E-24-7 & F-7-7 $2000
1967 3904391 single square port head rebuilt and stock C-15-7 $1750
1967 3885069 aluminum intake with center plenum removed 6-27-67 $300
1968 3919840 square port heads bare L-23-7 & D-23-8 ported $900
1968 3919840 square port heads bare both dated L-12-7 stock $1250
1969 3955272 396 4 bolt fresh 30 over J-8-8 all machined $1750
1969 3919840 square port heads all rebuilt both dated B-20-9 $1750
1969 3919840 square port heads both dated A-22-9 bare $1250
1969 3933163 aluminum intake dated 3-20-68 or 69 $300
1969 8 inch factory timing cover $150
1969 8 inch factory harmonic balancer $150
1969 427 covette oil pan off of 435HP $150
6223 steel crank freshly turned 20 under $300
6223 steel crank standard balanced to new keith black 9.5 to 1 closed chamber pistons mounted to stock gm rods $600
1969 427 4 bolt block 30 over 3955270 dated H-26-8 $4000
7/16 dimple rods $250
627990 square port heads complete $750
Edelbrock tarantulla style open plenum intake $100
330-770-2517 for any questions and can ship if you cannot pick up. Pictures available if needed. All parts have been cleaned and magged. Both intakes are cleaned up ready to go.
dlv4540 is offline   Reply With Quote
