Old 12-18-2011, 09:19 PM   #1
Racer4077
Default Shift on time or RPM
I would like to know peoples thoughts on shifting on the throttle stop. I have my TS coming on .200 after the hit...on for 2.500 (give or take). I have tried both shifting on RPM and time. I have been more consistant by shifting at RPM, but run a little more MPH on time shift. So I wanted to see what you guys are doing and what works.
Racer4077 is offline   Reply With Quote
Old 12-18-2011, 11:19 PM   #2
Chris Williams
Chris Williams's Avatar
Default Re: Shift on time or RPM
I'm in the time camp. Way more consistent for me. Car climbs when on the stop otherwise. But YMMV.
Chris Williams 6304 SC, TD, ET
Chris Williams is offline   Reply With Quote
Old 12-19-2011, 01:34 AM   #3
Mickey Whaley
Time is Time does it change? Stick to time unless u blow the tires off
Mickey Whaley is offline   Reply With Quote
Old 12-19-2011, 09:02 PM   #4
Racer4077
if my stop comes on @ .2....when do i shift? I'm on the stop for 2.5....
I've set it before at .7, but was thinking its too quick. any thoughts?
Old 12-19-2011, 10:32 PM   #5
Chuck Westcott
Chuck Westcott's Avatar
Smile Re: Shift on time or RPM
.2 on the stop is a good hit !
.80 on the shift is good for me with a stop RPM @ 4200 puts me close to a .90 run @ 165 or so in S/Gas Trim.
Your Stop RPM is important to be consistant if you running S/Gas or S/Comp.Alway's check stop RPM at every track !
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 12-20-2011, 01:05 PM   #6
Racer4077
Thanks for the info. Chuck. Sounds good to me. I will try it. I have another question for you if you don't mind. If my stall RPM is 5600, what should my on the stop RPM be? I was told to set it at 500 RPM lower than my stall, but I have had problems doing that and running a consistant number.
Old 12-20-2011, 02:37 PM   #7
Chris Williams
IMHO, you should set your stall at a number that gets you a time on the stop between 1.5 and 2.5 seconds (1.0 to 3.0 max) in any weather. Sounds like you could go lower and run on the stop just a little less.
Old 12-22-2011, 12:23 PM   #8
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
I shift on time as well. Timer one for the stop is .000, shift at .50-.75, looking for a 1.90 60' time, stop 2 timer is 4ish seconds for me now and down power RPM is 4100. This will get me a 10.90 in the mid/high 150's typically, or 11.05 in the mid 150's here in Vegas.
sst7250 is offline   Reply With Quote
Old 12-22-2011, 02:05 PM   #9
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
The reality is every car is going to like something differant. Chris is right, the best senario is 1.5 to 2.5 seconds. The problem is some cars, because of the power they make, will require a lot more time in the timer. My car goes on the stop at .07 and I am shifting at .30. I have my rpm's set at 3700 and will still end up with 4 seconds of time in the timer. I have been as fast at 9.90 at 174 depending on conditions
Chuck
C and W Racing is offline   Reply With Quote
Old 12-22-2011, 09:35 PM   #10
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
That must have been a windy day......lol
CBS is offline   Reply With Quote
