Old 12-15-2011, 01:42 PM   #1
JCChildress
JCChildress's Avatar
Liked 11 Times in 5 Posts
Default WTB Spool for 9" Ford
I am looking for a used lightweight steel 40 spline spool for a 9" Ford. I prefer a Mark Williams. I also have for sale, a detroit locker out of a Nascar 9" rear. Call with any info (434) 665-9541.
JCChildress is offline   Reply With Quote
Old 12-15-2011, 05:14 PM   #2
Paul Hellenberg
Default Re: WTB Spool for 9" Ford
Check you PM
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Paul Hellenberg is offline   Reply With Quote
Old 12-16-2011, 11:58 AM   #3
JCChildress
I forgot to mention it needs to be for the 3.250 brg
Old 12-16-2011, 04:01 PM   #4
mannymen
Liked 13 Times in 7 Posts
Doesn't the MW spool have to be run with their axles, due to the way they machine their units?
N/A
mannymen is offline   Reply With Quote
Old 12-18-2011, 01:35 PM   #5
Mark Ugrich
Liked 71 Times in 38 Posts
I believe the splines are cut at the outer ends of the spool on MW stuff.
Old 12-18-2011, 02:36 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
M/W and Strange splines are the same on 40 spline. M/W are a different pitch on 35 spline and will not interchange with Strange. The M/W 40 spline spools I own all have the splines cut all the way to the end of the spool. The Strange are recessed up inside the spool and require axles that are full length and end in the proper position to get a full spline engagement.
Adger Smith (Former SS)
