Old 12-11-2011, 12:46 PM   #1
looker_57
Default Engine diaper
I have a 1972 camaro back half car stock front end. I have a Dart lil M block with a Milodon 30908 oil pan. The Hedman hustlers are Very close on the starter side. I am wondering if anyone has this same setup?? and has done a diaper? What did you use? How much more did it cost to get modified? From what I have been seing most need to be modified ?
100_2101.jpg by looker_57, on Flickr
100_2097.jpg by looker_57, on Flickr
looker_57 is offline   Reply With Quote
Old 12-11-2011, 01:22 PM   #2
KEVIN T
Default Re: Engine diaper
Contact Dennis at DRE, he can make whatever you need.
Kevin T
KEVIN T is offline   Reply With Quote
Old 12-11-2011, 03:39 PM   #3
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Engine diaper
No problem Looker we can get you fixed up call me 217-454-5289
DIAPERMAN is offline   Reply With Quote
Old 12-11-2011, 04:39 PM   #4
looker_57
so even with my clearance around the starter and header tube being about jean thickness,thats with the mini starter, you can work around that? I tried to call the number best time to call I assume would be monday?
Old 12-11-2011, 06:30 PM   #5
DIAPERMAN
Yes call Monday please No problem to fit we go behind stater
Old 12-14-2011, 01:21 PM   #6
GRIGGS
My dad has a 72 camaro with a big block. DRE made us a diaper to fit with no problem. Even made provisions for going around the stock motor mounts
GRIGGS is offline   Reply With Quote
