Old 12-10-2011, 03:23 PM   #1
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Question GM Performance Parts BBC Block Question
A question for the engine builders out there...
I am looking at the GM Performance Parts BBC block, part # 19170538. The block is made for use with a 1 piece rear main seal crank and oil pan. I see that there are adapters to convert it for use with a 2 piece rear main seal crank. Is there a way to convert the block to use the 2 piece rear main seal crank and oil pan? Looking at the higher end bowtie blocks with 2 piece rear main seals, it looks like they use a 2 piece rear main seal main cap and some sort of aluminum adapter plate bolted to the block. I don't see any listings for the main cap or adapter plate, nor have I found anything with other manufacturers.
Any insight would be appreciated. Thanks!
Jeff Jewell
