Old 12-05-2011, 01:00 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Cragar SST Unilug Wheels ?
Does anyone know which washer and lugnut to use on a 1972 Olds Cutlass when installing old Cragar SSTs (street version of the super tricks?
Is the olds a 7/16ths or 1/2 diameter stud
N/A
mannymen is offline   Reply With Quote
Old 12-06-2011, 12:36 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Cragar SST Unilug Wheels ?
The 'unilug" was an oval shaped wheel stud opening that would allow for either a 4.5" (AMC, Ford, Mopar) or 4.75" (GM) bolt circle using only (5) openings in the wheel (versus the Cragar Super Tricks and later Weld Wheels that had a total of (10) openings per wheel top accomodate both bolt circles). They sold a lug nut washer which had the same shape and when it was all bolted on the car, you saw 5 lug nuts and no open areas.
I'm guessing this is what your looking for?
And I would also guess an Olds is 1/2" x 20 wheel stud.
Jeff Lee 7494 D/S '70 AMX
Old 12-06-2011, 01:08 AM   #3
mannymen
All set. Emailed Cragar and Mccormack racing and got the right washers and lugs. Thanks
N/A
Old 12-06-2011, 07:36 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Olds is 7/16" Correct?
Old 12-06-2011, 03:59 PM   #5
mannymen
7/16 is correct
N/A
