Old 11-28-2011, 01:09 AM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default 2-Step with a Stick Shift ONLY please !!!!!
I just went through a number of old threads on 2-steps.
I think my head is going to explode !
Brake pressure switch ??????? WTF is that for ?????
Anyhow...
I need to get my 2-step wired into my car ( along with the line-lock that I still haven't installed ).
I need it to hold about 6000 RPM while in first gear, clutch pedal depressed...
But once I leave... allow me to shift around 7000.
How the heck do I do that ? !
I'm expecting a big education here !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 11-28-2011, 01:44 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: 2-Step with a Stick Shift ONLY please !!!!!
Put a switch on the shifter that over rides the two step. Probably will be where you have your line lock switch now.
2009 V/SA Record Holder
Old 11-28-2011, 09:58 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Brake pressure switch on a stick shift car helps you be consistent. When you stage the car, find through experimentation what is the minimum safe brake line pressure necessary to hold the car still while staged. Then the release time of the brake system becomes a consistent factor in the "leaving event". The more pressure you build into the brake system, the longer it takes to release it.
Since you currently do not have a line lock, the brake pressure switch is not an issue, unless you have three feet.
Old 11-28-2011, 10:04 AM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
This is easy, you need a switch that activates only when the clutch is pressed completely to the floor, I use the arm type switches the chassis places sell cause they're easy to adjust. You can use this set up cause no one presses the clutch completely to the floor on a gear change, believe me I know it works. I've wired up a relay in the past hooked to the line lock that deactivates the line lock on clutch release that way you have the line lock holding the car in the beams. Joe
Joe Buchanan SS/BX 3117
Old 11-28-2011, 10:53 AM   #5
http://www.msdignition.com/uploadedF...structions.pdf
See figure six. That allows you to hook up a line lock and a clutch pedal switch on a stick car. Once you stage, and step on the clutch, release the line lock button, the switch on the clutch pedal holds the line lock, holding the car on the starting line until you let the clutch go.
Old 11-28-2011, 11:56 AM   #6
buzzinhalfdozen
Wow, thanks Alan I've never seen this before basically how I had my stick car set up. Their schematic is much easier to read than my "art work" thanks for the link guess I never thought to look there.This looks very easy to set up. Joe
Old 11-28-2011, 12:08 PM   #7
It's easy enough that even I could do it! It takes a lot of opportunity for "stupid" away from the driver, not enough to make up for my having not raced a stick car in near 20 years, but it helped. We had it set up on an MSD 7AL-3, it worked like a champ, especially when the 220# of ballast that was holding the steering wheel did its job. Which was not often enough. I think I made a dozen passes in that car in a year, only 4-5 of them were decent.
Old 11-29-2011, 12:21 PM   #8
Aubrey N Bruneau
aaaahh... but is it enough ?
I tend to seize every possible "opportunity".
Thanks people !
Now, with a couple switches and about 8 wires to install... the question becomes...
will I have enough time between now and May, to figure out how to do it ?
Old 11-29-2011, 06:22 PM   #9
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Thanks people !
This may be a slightly silly question related, but my green challenger that we put the stick back into has one of those RPM activated switchs in the glove box..and a msd 73al with a 3 step...prior owner had a transbraked auto in it, and we couldn't figure out what the rpm activated switch was for....had a 6k chip in it and the car would lay over at the line sometimes so I threw a 7200 or 7400 in it, still layed over every 2-3 runs.....might have been a fuel pressure issue.....I ended up doing some wall quality control testing with the RT at Napierville so this thread is quite helpful!
thanks
Eric
Eric Merryfield 1883 STK
Old 11-29-2011, 06:34 PM   #10
ShadowLands
ShadowLands's Avatar
....will I have enough time between now and May, to figure out how to do it ?
Well you're the one living north of the Arctic Circle, man.
ShadowLands is offline   Reply With Quote
