Old 11-28-2011, 01:05 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 L78 396 Block and #163 Aluminum Intake
1969 396 4 bolt block freshly bored 30 over and decked with casting number 3955272 dated J-8-8. Block has new cam bearings and freeze plugs and line bored all checked out good $1750. 3933163 aluminum intake dated 3-20-69 all cleaned up with small weld repair on topside $350. 6223 steel standard crankshaft balanced to new closed chamber keith black pistons and factory GM rods. The pistons are a #160 series for around 9.5 to 1 with a 105CC closed chamber design head. $600 for the rotating assembly and would work well with the block. Will package deal all of it for $2400 and can ship if you cannot pick up. 330-770-2517 for any questions or pictures needed.
dlv4540 is offline   Reply With Quote
