Old 11-26-2011, 11:15 AM   #1
Jonathan Anderson
Default Everything must go!!!
Holley Dominator #12R-4325B List #4575 1050 CFM with QFT metering blocks $350
Holley Dominator 12R-8975B List 8896 1050 No screw in air bleeds $275 Barry Grant 750? vacuum secondary electric choke $100
2x Barry Grant 280 Fuel Pump $150
Barry Grant Fuel Filter $35
Wilson Alcohol Dominator PN BG8896-4 Needs freshened $350
4500-4150 adaptor $30Edelbrock Victor 454TD Rectangle Port 4500 Intake $150
Weiand Team G Rectangle Port BBC 4500 drilled and tapped for NOS or Rons Fuel Injection $100
Biondo Inline Throttle Stop PN PCTS $150
K&R Throttle Stop (no solenoid) $125
Gold Crane Stud Girdle for BBC (set) $125
Scott Shafiroff Stud Girdles $150
Reher Morrison Stud Girdles $150
Crane Gold Rocker Arms BBC $10 a piece
Ball Milled Polished BBC Valve Covers $50
Shorty Glide stock case 1.76 low hardened turbo input shaft pro tree transbrake $800
2x Powerglide stock case 1.76 low gear dual ring servo hardened turbo input shaft pro tree trans brake deep pan (Neal Racing Transmissions)$850
Powerglide stock case 1.76 low gear dual ring servo hardened turbo input shaft high gear only with new FTI converter (for high gear only) deep pan $1975
Hurst Shifter with T handle and line lock button front cable exit, shifter cable, and Biondo Electric shift solenoid $175
Hurst Quarter Stick T350 front cable exit shifter only $60Hipsters P/G Pro Tree Aluminum valve body new never used $250
Digital Delay Delay Box (Crossover Thumbwheel Type) $100
Alston Chassis Rocker Switch Panel $50
2x MSD 7AL2 $275
MSD 6AL $125
MSD Electronic Timing Control PN 8680 (like new) $90
MSD Distributor PN 8570 Bronze gear $125
Wysco PN WP8909 HEI distributor $50
Moroso Electric water pump drive kit and spare motor $75
3x Aluminum Swivel thermostat housings $45 a piece
Weiand Aluminum Water Pump $50
Moroso Water Pump $45
Moroso Water Pump (outlet has been relocated) $45
Most Prices negotiable
Shipping Price is not included
All parts are for BBC
Any Questions please call 404-805-5129
Jonathan Anderson is offline   Reply With Quote
