Old 11-24-2011, 11:52 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question Roller rocker ratio
So if I read the rule right I can put 1.70 arms on the 230 6cyl instead of "factory" 1.75? (Harland Sharpe makes a 1.7 for the 230.....the factory arms that are on the car are anywhere from .354 to .382 lift .388 is spec)
Old 11-25-2011, 04:16 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Roller rocker ratio
This no rocker ratio listed has just opened a can of worms. When you just have a lift rule there are all sorts of ways to design the cam and rocker ratio to get the job done. Talk about different lobe designs. One thing I would not do is use a rocker that had it's actual ratio or any ratio stamped on it. Ask Jeff teuton about that!!
Adger Smith (Former SS)
Old 11-25-2011, 03:02 PM   #3
Reed Granrt
NoNoNo Adger, You missed the point. Have the rockers stamped with the ratio you want on it. They will not know how to measure to see what it really is.
reed
Reed Granrt is offline   Reply With Quote
Old 11-27-2011, 11:39 AM   #4
Jason
Liked 6 Times in 4 Posts
reed
Is that so? I would think a techman knows to measure the lift at the retainer and then at the lifter. Simply divide for the ratio.
Good luck if you think you can slip that past anyone.
Jason is offline   Reply With Quote
Old 11-27-2011, 12:17 PM   #5
Ed Wright
Ed Wright's Avatar
reed
That's funny right there! I don't care who ya are.
Ed Wright 4156 SS/JA
Old 11-27-2011, 10:58 PM   #6
SS Engine Guy
Been done for years.
SS Engine Guy is offline   Reply With Quote
