Old 11-20-2011, 11:31 PM   #1
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default BB Chevy eating keepers
What would be the most likely cause of our engine chewing up keepers? It's a around 480 cu and we run a Comp Cams flat tappet cam. Sept of last year we caught one before it dropped a valve and replaced them all. Now one year later it happened again and it's on four different valves. I feel like we have used up all our luck and better get on top of this. Most seem to think bad springs are causing float or bad batch of keepers. Opinions? Thanks in advance.
Old 11-21-2011, 08:59 AM   #2
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Re: BB Chevy eating keepers
The two things that I would look at is make sure that the rockers have sufficient clearance by the retainers. Also make sure that your valve train geometry is correct and not causing excessive side load on the valve as it is opening
Chuck
C and W Racing is offline   Reply With Quote
Old 11-21-2011, 09:18 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
X2 on the rocker clearance.
If the rocker is contacting the retainer and leaving wear marks on the bottom of the rocker ,that could be your problem.
Really weak springs could be letting the valve bounce as well , that'll cause a whole bunch of valvetrain wear and breakage.
Old 11-21-2011, 06:44 PM   #4
tommy d
tommy d's Avatar
Thanks for the reply's. The rockers HAVE been hitting the retainers very slightly and I didn't even make that connection. The springs have a ton of runs on them as well. I thought we had changed them out at least once since this problem surfaced but we haven't. Think I'll pull the heads and really go over everything.
Old 11-21-2011, 07:42 PM   #5
Liked 1,925 Times in 432 Posts
If the rockers hit the retainers, they're tilting the retainers and trying to un-key the valve every time the engine spins over 4 times. You're lucky that you haven't done even more damage. That is most certainly the problem.
Most modern rockers for a big block will clear a 1.650" spring and retainer with relative ease, provided the valvetrain geometry is correct.
Old 11-21-2011, 09:04 PM   #6
tommy d
tommy d's Avatar
I'm wondering about the geometry. We do run lash caps and I can see witness marks on the underneath side so they must be the right depth. If I remember correctly the lash caps were supposed to help a geometry problem that we had. Will T&D or Jesell shaft rockers eliminate that problem?
Old 11-22-2011, 01:30 AM   #7
Well, shaft rockers are the way to go, if you can afford them, and Comp has a good deal on theirs.
If you're running lash caps and you're still hitting the retainers with the rockers, odds are your pushrod is too short.
Old 11-22-2011, 09:52 AM   #8
Ron Finney
Ron Finney's Avatar
You definitely need to check the pushrod length also. This is something a lot of people never check. It isn't hard to do though. Set up one rocker and watch the tip as it rolls across the valve stem. It should stay in the middle of the valve stem the majority of its travel. Since it swings in an arc it will move back and forth, but should not come off the edge of the stem. As the previous post suggested, you may need a slightly longer pushrod. You definitely need springs though if you have that many runs on them.....another often overlooked item that is worth a bunch of power.
Good Luck!
Ron Finney 396V S/C
Ron Finney is offline   Reply With Quote
Old 11-22-2011, 11:26 AM   #9
Chuck Westcott
Chuck Westcott's Avatar
Cool Re: BB Chevy eating keepers
TD,
How do run so consistant with that issue ?
I don't know about the rest of you but I change out the springs every 100 runs or so. Sounds to me that the PR length is on the short side, easily confirmed with a good set of length checkers, I have a set in my trailer if you need to borrow them. I also know where you can buy new pushrods- Smith Brothers !
Just don't set on it fire again ! If I'm not there.
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 11-22-2011, 03:07 PM   #10
C and W Racing
Chuck, I'm not thinking this is the Tommy D that you are thinking it is. Unless you know two of them that have set their car on fire. lol
Chuck
