Old 11-12-2011, 12:15 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 3933163 Aluminum Intake & 3919840 Heads
3933163 factory aluminum square port intake cleaned up and dated 3-20-68 or 69. I can't make out the last digit good enough to tell. The intake is stock and has one weld repair on topside around one outside bolt $350. 3919840 square port heads both dated A-22-9 and are a stock set. The heads were magged and one is good and the other has a crack in two seats that will need replaced and one goes right above which would either need ground out or pinned $800. 330-770-2517
dlv4540 is offline   Reply With Quote
