Old 11-08-2011, 11:54 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1967 L78 396-375HP MQ out of Camaro
Sale Pending
I have a late built 1967 L78 396 4 bolt longblock out of a camaro. The block casting number is 3916323 and the block is dated F-8-7 with the front pad stamped T0705MQ 7N252794. The motor is standard bore with the original internals still in place with the exception of the cam and lifters being replaced. The motor has the 3919840 square port heads on it dated E-18-7 and E-23-7 and have been redone with newer springs on them. The timing cover, harmonic balancer, waterpump, alternator pulley, oil pan, chrome valve covers, push rods and the motor mounts are with it as well. The internals look great and the cylinders look clean. Very nice hard to find motor $5500. I can ship it if you cannot pick it up. Any questions or pictures needed I can be reached at 330-770-2517.
dlv4540 is offline   Reply With Quote
