Old 10-07-2011, 11:02 PM   #1
Superman 4126
Default 433 Cui Big Chief
433 cubic inch big block. 16 degree olds big chief heads by (CFE),Manley titanium valve springs,J-E pistons,MGP rods,Bryant crank. 4.600 bore x 3.250 stroke,60 mm LSM cam,jesel shafter rockers,jesel keyway lifters,dual 1300 cfm carbs (braswell),custom sheet metal intake by (CFE). Dry sump,vacuum pump,Davis pro stock step headers w/egt sensors,4-7 odd firing order. Front drive distributor,belt drive. Intake 2.375/exhaust 1.80.........engine made 1,075hp@645.6ftlb trq. Best et 6.95@191mph....priced to sell race ready minus starter,and flywheel $13,500........minus carbs,starter,flywheel 10,500. Less than 8 total runs......434smallblock@cox.net
Superman 4126 is offline   Reply With Quote
Old 10-10-2012, 08:29 AM   #2
Michael H.
Default Re: 433 Cui Big Chief
Michael H. is offline   Reply With Quote
