Old 10-07-2011, 10:57 PM   #1
jimi
Liked 21 Times in 8 Posts
Default Hemi maxwedge small block w8 etc.
im cleaning house !
Hemi stuff
1.nascar hemi bathtub with two tops $2500.00
2.barton hemi crossram $1700.00
3.65 hemi cross ram intake manifold $5000.00
4.65 hemi a 990 hood latch support $250.00
5. 65 hemi belvedere lower front valance $250.00
6. 8 new chrysler 12.5 to 1 hemi forged pistons $ 400.00
7. 8 new and used hemi roller cam shafts $50.00 each (all .400 plus lobe lift)
8. 2 8 bolt hemi cranks 1 street hemi 1 kellogg $250.00 each
9. brandywine hemi composite tunnel ram intake needs crack repaired $ 800.00
10.2 15x14 crager super trick rear wheels $400.00
11.2 1965 a990 aluminum water pump housings $250.00 each
12. 3 sets hemi k valve covers all nice shape $800.00 set
13. 65 hemi timing cover and balancer $200.00
14. 1964 3861 hemi cross ram carbs $2000.00
15. 3 set hemi headers various makes $450.00 per set
16. 64 belvedere aluminum hood latch support $1500.00
17.1964 belvedere hemi shock tower $1000.00
18.used milodon hemi oil system parts $?
19.1965 hemi automatic manual valve body $200.00
20. 2 1968 hemi s/s distributors with cd box $ 1000.00
21.1965 belvedere a990 hemi car # 22 $150,000.00
car comes with win jackets, trophies,medallions
magazine articles,national record certificates
and various pictorial collection
maxwedge stuff
1.1964 aluminum maxwedge hood scoop $2000.00
2.1964 maxwedge stage 3 intake manifold $2500.00
3.1964 max wedge nascar intake manifold $3500.00
4.set max wedge connecting rods $ 400.00
5. 1962 413 max wedge "286" cylinder heads $2000.00
bronze guides, chambers and runners cc'd, stock elimnator
valve job, needs valves springs and retainers.
pressure tested NO cracks!
6.1963 max wedge intake $ 1500.00
7. 1962 "3447" max wedge carbs $$1500.00
8.1 set hooker max wedge 2 1/8" headers $ 450.00
9. 1 new 413 marine short block $1200.00
10. 1 used maxwedge alternator dual belt pulley $100.00
various big block parts
1.1962 361 305 hp aluminum intake manifold $175.00
2.1962 361 305 hp oil pan $75.00
3.1962 383 343 hp carbs and intake $ 2000.00
4.1962 383 343 hp cheater carbs 750 cfm $500.00
5.1 set 440 six pack connecting rods $200.00
6. 1 set 1967 440 magnum "915" cylinder heads
bronze guides , pressure checked $750.00
7.1962 361 305 hp block crank and cylinder heads $500.00
8. std. bore 440 ci short block, 1/21/70 casting over counter replacement
only run in on engine test stand $ 1500.00
9.8 440 steel cranks all need resizing $50.00 each
10.4 440 blocks all need tank bore and hone $ 200.00 each
11. 1 383 block $ 200.00
12. 1 361 block $ 200.00
13. 8 sets of various big block heads 906 452 346 castings $ 100.00 set
interior /exterior
1.1964 belvedere steel nose two beautiful fenders two hoods one flat
with 426 emblem second cut for scoop and bumper $5000.00
this front end has never been street driven it was replacement sheetmetal
hood still has p number on bottom side
2.1964-65 wedge k frames $250.00 each
3.2 1962 dodge b body front grilles $ 450.00 each
4.1963 savoy wagon tail lights $ 100.00
5. 1965 belvedere taillights $100.00
6. i set 1965 belvedere head light bezels $ 250.00
7. 1964 belvedere head light bezels 3 sets $250.00 set
8. 3 1964/65 b body radio delete plates $200.00 each
one delete plate cut for two gauges
9.1964 belvedere dash cluster,push buttons with cables and
heter delete plate $ 1000.00
10. various 62-64-65 b body stainless trim $?
small block
1.2 new 318 poly blocks with pistons $500.00 each
2. 2 sets poly cylinder heads $150.00 set
3. 1 360 block $ 150.00
4. 1969 340 factory cast iron intake $ 200.00
1964 plymouth belvedere aluminum nose s/s car dana 4 link roll cage etc.
has max wedge in it now was run as ss/ba hemi car for many years
will sell less engine and trans.
$75,000.00
1962 dodge dart 440 wagon "the behemoth" c/sa max wedge 413 ci
$65,000.00
1996 dodge avenger ss/am-dm w8 small block has run 9.15 145.00 in ss/dm
with 300 ci engine will sell less engine trans and third member
$75,000.00
please ask for pictures to be emailed or give me a call 845 298 9041 all prices negotiable.
