Old 09-22-2011, 05:43 PM   #1
Jeff Stout
Liked 704 Times in 281 Posts
Default 85 Monte Carlo SS GT super stock
1985 MONTE CARLO SS
SUPER STOCK LEGAL GT/AA TO GT/MA
SET UP FOR BBC/T-400
MILES 10K ON BODY
WHEN PURCHASED FROM ALLSTATE INSURANCE FROM THEFT RECOVERY
SENT TO ED QUAY AND SPENT OVER $12K IN
BUILD OF CAGE AND SUSPENSION IN 1985
CHROME MOLY CAGE CERT T0 8.50
FUEL SYSTEM
ALL MAGNA FUEL THROUGHOUT
2 PORT REGULATOR
JETTED BYPASS RETURN
500 PUMP
HI FLOW FILTER
5 GALLON CELL
BRAKES
LAMB/WILDWOOD CALIPERS AND ROTORS FRONT AND REAR
MASTER CYLINDER AND BLOCK OFF PLATE
2LB INLINE PRESSURE VALVE
SHOCKS AND SPRINGS
FRONT DOUBLE ADJUSTABLE (30 PASSES)
MOROSO TRICK SPRINGS (LIGHT BBC WITH NO COILS CUT)
REAR DOUBLE ADJUSTABLE AND RE-VALVED BY LAMB FOR HEAVY CAR
LAMB 130 LB SPRING WITH WEIGHT JACKS TO HELP SETUP 4 LINK AND RIDE HEIGHT
SUSPENSION
STOCK FRONT A-ARMS WITH REFITTED LOWERS TO HELP IN CAMBER ADJUSTMENT
S-10 BOX
VW STEERING DAMPNER
3 PASSES ON NEW HEIMS FOR FRONT END STEERING ($100)
SEVERE DUTY 4 LINK MOUNTS AND RODS WHEN QUAY BUILT CAR
3 PASSES ON ALL REAR 4 LINK HEIM ENDS AND WISHBONE HEIM ENDS ($550)
FORD 9 WITH REINFORCEMENT
5.67 PRO GEAR
STEEL STRANGE SPOOL 35 SPLINE
STRANGE STEEL THIRD MEMBER
LONG AXLE IS MARK WILLIAMS RIFLE DRILLED
SHORT AXLE IS STRANGE SOLID
3 1/2 DIAMETER DRIVE SHAFT
ELECTRICAL
STOCK HEAD AND TAILLIGHTS WITH SS DASH
PAINLESS SWITCH PANEL
ULTIMATE II PLAYBACK TACH
2 5/8 AUTOMETER OIL,WATER AND FUEL
1 5/8 VACUUM GAUGE
SHIFTER
CHEETAH REVERSE VALVE BODY
AIR/ELECTRIC WITH BOTTLE AND REGULATOR
ACD DUAL RPM SHIFT COMMAND CENTER
MSD DIAL MODULE FOR RPM SELECTION
ADJUSTABLE LONG TRAVEL TRANS BRAKE BUTTON
EXHAUST
MCCABE BUILT 2 1/8 STEP HEADERS IN 1996
BURNS STAINLESS STEEL MERGE COLLECTORS ($600 WITH 3 PASSES ON THEM)
TIRES
WELD 3.5 WITH 28 TALL MOROSO
WELD 12 WITH 14X32 GOODYEAR (8PASSES)
I HAVE OWNED THIS CAR SINCE 1989 AND ORIGINALLY IT WAS WHITE WITH RED INTERIOR AND REPAINTED FORD TEADOR RED IN 1995
NEW FRONT DRIVERS FENDER AND REAR SPOILER AND TAILLIGHT HOUSING ALL REPAINTED AND READY FOR INSTALL
THINGS NEEDED TO BE RACE READY
MOTOR,TRANS, BUILD CROSSMEMBER TO FIT OIL PAN, FRONT END ALIGNMENT, 4 ROTORS,INSTALL FENDER,SPOILER AND TAILLIGHT HOUSING, FUEL CELL LEAKS AT TOP WHEN FILLED COMPLETELY UP, MAYBE BRAIDED FUEL LINE AS IT MIGHT LEAK FROM SITTING DRY, 2 BATTERIES, UPDATE SEAT BELTS, NEW CHASSIS CERT.
I do not have a title only a bill of sale. If a title is needed it will show as salvage due to theft recovery and stripped for more then rebuild in 1985. Asking $8500.00 OBO Phx AZ 602-768-3583 pics emailed if serious
