Old 09-22-2011, 01:57 PM   #1
dussault.racing
Default super comp license questions
Was wondering... Do passes need to be made at the same track?
Do they want the T. stop turned off or used to limit each pass??
Thanks
dussault.racing is offline   Reply With Quote
Old 09-22-2011, 02:32 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: super comp license questions
most likely just a wide open trottle--no electrics/mechanics involved--- I'm sure you can do different tracks---xHRA is more interested in your capabilities as a driver at certain speeds not "running the number" and you will need to get drivers that have a license classification either the same or higher than the license you are seeking--remember you also will need the TRACK MGRS signature & to remember to attach your time slips with your license application- 1/8 mile times will work in lieu of a quarter mile track as long as the numbers are there----FED387
Old 09-24-2011, 12:42 PM   #3
hookdaddy
Liked 8 Times in 3 Posts
When I was doing my license runs I was also told that all runs needed to be single passes - they would not accept any run with someone in the other lane.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
