Old 09-07-2011, 08:36 PM   #1
Superman 4126
Default 433 cubic inch bbc
433 cubic inch block. manley titanium valves,16 degree olds big chief heads (cfe). J-E pistons,MGP rods,bryant crank,LSM cam jesel keyed lifters,dual 1300 cfm carbs,custom sheetmetal intake,(cfe) drysump,vacuum pump,davis pro stock step headers w/egt's. 4-7 odd swap firing order,front drive distributor,belt drive,reactor flywheel, 4.600 bore x 3.25 stroke. peak hp 9700rpm's......makes good power and trq......504-269-7073
Superman 4126 is offline   Reply With Quote
