Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 09-05-2011, 06:29 PM   #1
PROTREE
Default rpms past peak
how many rpms do you guys go past peak hp across the stripe.
PROTREE is offline   Reply With Quote
Old 09-06-2011, 09:13 AM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: rpms past peak
Four to six hundred
don,t have one
Old 09-08-2011, 08:47 PM   #3
Charlie Yannetti
Liked 192 Times in 83 Posts
Around 200 below.. you want the motor to be pulling going out the back door, not nosing over cause you ran it out of the power band..
Check your dyno sheet.. it will show you where your motor starts to lose power.. that's where you DON'T want to be on shift points or at the finish line..
Charlie Yannetti is offline   Reply With Quote
Old 09-09-2011, 08:52 AM   #4
randy wilson
To each his own, I say.
don,t have one
Old 09-13-2011, 08:04 AM   #5
69Cobra
Liked 2 Times in 2 Posts
I agree with the 4 to 6 hundred over.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 09-19-2011, 08:44 AM   #6
Tilley2007
Guest
Posts: n/a
Through my experience, my best ET's are when it is just noseing over. It does hurt speed however.
