Old 08-28-2011, 10:28 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-69 396 & 427 Hi Performance Parts
3873858 square port heads rebuilt D-18-6 & E-2-6 $2500
3873858 square port heads bare F-13-6 & F-17-6 $1750
3904351 427 4 bolt standard bore block H-18-6 $5000
3919840 square port heads rebuilt F-17-8 & F-18-8 $1500
3935440 396 4 bolt standard bore block E-21-8 T0524MQ $1250
3955272 396 4 bolt L89 J-7-8 T1014JJ 1 of 311 $3000
3955272 396 4 bolt L89 J-14-8 T0527KG 1 of 400 $3000
3919840 square port heads both dated J-31-8 $1250
3919840 square port heads both dated C-25-9 $1250
3919840 square port heads J-31-8 & K-4-8 (slightly ported on exhaust side) $1100
6223 steel crank 10 on mains 20 on rods ready to go $300
8 inch timing cover with teeth design timing tab $100
#5271 primary metering block Holley carb $35
Secondary housing with screws Holley carb $15
3909879 F-24-7 & 3916178 F-28-7 smog exhaust manifolds repainted $500
330-770-2517 for any questions or pictures needed and can ship parts if you cannot pick up. All blocks and heads were cleaned and magged.
dlv4540 is offline   Reply With Quote
