Liked 132 Times in 30 Posts
Are there any Ford racers out there who've tried using a factory style TFI distributor on an older engine (i.e. 289, early 302) with carburetor(s) or non-ECU application????
Gary Smith "another broke racer spectating" |
I put a bracket/ strret car together for a friend a couple years ago and used the stock TFI dizzy with a MSD box and a start retard box. Seemed to work fine for him, It was a stick car with nitrous so I'm not sure how consistent it was but it ran hard for a 302. Low 12s at over 122 mph.
2009 V/SA Record Holder |
do you remember how you wired it up?
Liked 79 Times in 11 Posts
make sure and change the dist gear if the engine uses a flat tappet cam.
bob beals 7244 |
