Old 08-24-2011, 02:59 PM   #1
jeremy341a
Default 1927 left steer Roadster
1927 Roadster Left Hand Steer
105 inch wheel base
mild steel chassis
Ford nine inch with alum center section
lader bars
509 bbc
4.500 bore and 4.00 stroke
Wiesco Pistons with a 1.645 compresssion height
Oliver rods
GM Performance forged crank
11.3 to 1 compression
Comp custom hydraulic roller camshaft cam with .647 lift, 256/262 @.050
Moroso pan,
GM Aluminium heads (12363391 GM part number 2.25/1.88 valves), 290cc intake runner that flow 330 at .700 lift, 320 at .600 lift. Harland sharp roller rockers 1.7
BTR alky dominator
bo laws internal bypass belt drive fule pump
meziere electric water pump
msd distributor
msd crank trigger
east coast alternator
powerglide trans with ultra bell
B@m 26000 8" converter
weld wheels
hooiser slicks 33X14.5w
optima battery
racecraft switch panel
B@m prostick with electric shifter
autometer guages
mega 400 delay box
msd 7al2 igntion with 3 step
delay box is setup with quick disconnect plug for footbraking
$10,000 rolling $18,000 turn key
car runs 5.6's at 120mph
car weighs 2160 lbs but that is with almost 200 lbs extra bolted on.
any questions
573-694-0247 can email pics, just send me a email with email address
mckaguej@chamois.k12.mo.us
jeremy341a is offline   Reply With Quote
