Old 08-23-2011, 07:27 PM   #1
Chris Butcher
Default S/St NHRA
What are the rules as to chassis cert..... i would like to run Beech Bend S/St but my NHRA chassis cert is out...car runs 6.20-6.25 wide open but not sure how it works on the 10.90 index.
Also if i get there Saturday morning will it be ok and have time to run the event.
Chris Butcher is offline   Reply With Quote
Old 08-23-2011, 08:04 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,221 Times in 980 Posts
Default Re: S/St NHRA
You probably won't have time to get it certified there on Saturday morning and be prepared to get only one run, there will be a ton of cars there...depending on your setup you'll be on the edge of running 135 or over which would put you over the limit for no cert so you'll have to adjust your timer to kill a bit of top end.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-23-2011, 08:45 PM   #3
Bob Verwold
Bob Verwold's Avatar
The time run for Sat is 8:00AM and eliminations at 2:00PM . The tech is open from 7:00 - 12:00 your pushing a fine line..........Come on in the water is fine...lol
Bob Verwold is offline   Reply With Quote
Old 08-23-2011, 09:28 PM   #4
Chris Butcher
I just started running the Pro Tree stuff this year been running IHRA and was just wondering...havent ran any 1/4 mile stuff either.....have to work friday and was gonna maybe go test at Mt Park on 1/4 mile then head that way....will see what i can do.
Old 08-23-2011, 11:55 PM   #5
DIAPERMAN
Liked 21 Times in 6 Posts
Chris look me up if you need a diaper to get through tech we will be there DRE
DIAPERMAN is offline   Reply With Quote
