Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 08-23-2011, 01:18 PM   #1
joespanova
Liked 13 Times in 11 Posts
Default Rev limiters / launch
I figured either Comp or Pro Stock guys would have the best answer for this.........Super Stock guys , please answer if you use manual trans.
Mostly for the manual trans guys................what are you using for an RPM limiting device at launch? 2 step , or is there something "easier" on the engine / better to use?
The point I 'm trying to get an answer for is that either they ( Pro Stock , etc ) launch at such a high RPM the engine "sounds" smoother or they are using a different device..............which is it?
