Old 08-23-2011, 08:37 AM   #1
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Unhappy C12 vs pump gas
I have a low compression 340 combo,and when I put c12 or blue in it, it's starts to skip at high rpm in high gear (5800 to 7000 rpm) but with high octane pump gas it runs clean.any help would be great.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 08-23-2011, 09:10 AM   #2
Bob Verwold
Bob Verwold's Avatar
Default Re: C12 vs pump gas
Not knowing the rules for stock fuel and your compression this is just a guess, but I'd think you don't need that much octane and at $10.50 a gallon I'd use pump gas.
Bob Verwold is offline   Reply With Quote
Old 08-23-2011, 09:16 AM   #3
dartman
dartman's Avatar
i do when i can but @ nationals and Lucas Oil Drag Racing Series they have fuel check,and you have to have their fuel.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
Old 08-23-2011, 11:08 AM   #4
Ed Wright
Ed Wright's Avatar
Use C11 at the track, and fatten it up a bit.
Ed Wright 4156 SS/JA
Old 08-23-2011, 11:47 AM   #5
Mike Croley
I don't imagine that the brand X race fuel is your problem . Your combination shouldn't require a lot of motor octane . Truthfully , if it runs good on 92 or 93 octane i'd stay with that . Keep a close eye on the plugs at all times , and if you ever see any evidence of detonation , switch to a good 110 . The difference in price between pump gas and race fuel isn't really very significant when you consider the relatively small amount of fuel you use at the track .
Mike Croley is offline   Reply With Quote
Old 08-23-2011, 01:04 PM   #6
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
You may try C-10
Old 08-23-2011, 08:27 PM   #7
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Jet up 6-8 numbers with the good stuff. Possibly more with Sunoco Blue. When guys pick up .15 with the blue it's because they are pig fat. You are lean either due to jetting or insufficient volume.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 08-23-2011, 10:43 PM   #8
Chad Rhodes
the best pass my camaro has ever made it had 93 octance from the corner convenience store in it. But it was the middle of January
Chad Rhodes 2113 I/SA
Old 08-24-2011, 12:52 AM   #9
Pat Cook
Be leery of pump gas. Had a friend who worked for a car company as a calibrator. They were having problems with engine detonation, so on a calibration drive from Michigan to Arizona they decided to do spot checks on pump gas from across the country. What they found was, what was being advertised on the pump, did not match what was coming out of the nozzle. Nor saying that all gas stations are like that, but I know of a convenience store that will order fuel and fill the regular tank and top of the premium tank with the same tank truck….
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 08-24-2011, 11:34 AM   #10
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
And I thought that only happened in Kingman, AZ!
Eddies66 is offline   Reply With Quote
