Old 08-22-2011, 07:37 PM   #1
CraigG
Liked 9 Times in 8 Posts
Default Valve Leakage Check?
Hey Everybody,
I have E-heads with swirl polished valve, solid roller springs and multi-angle seats.
I tried windshield washer fluid and the inner springs installed without the spring pocket shims - the valves wept after a couple hours and puddled in the ports overnight.
Valid test? or is there a better way to check for leaks with the heads off?
Thanks Again, Craig
CraigG is offline   Reply With Quote
