Old 08-22-2011, 01:52 AM   #1
TD561
Default Garage Sale
I have sold my TD and have bought a stocker. I am selling all parts in order to change my inventory to help my stock efforts. ALL ITEM ARE MAKE OFFER. If it's reasonable it's yours.
ATI Turbo 350 with ATI Treemaster 8 inch converter both have just came from Abruzzi for freshen. In ISA car now. Trans has reverse VB and has some other mods.
Chrome dial mount with flip a dial for flat tray
3 pair Strange gold brake pads for rear setup 9 inch
Comp Cams BBC Stainless roller rocker arms.
PG shorty trans rear cover, hardened input shat, locking dipstick, pro tree brake with aluminum pan and Shield. HAS BROKEN PLANETARY
Flatlander chute and pilot in Stroud packing bag
Aerospace Calipers and brackets 9 Inch Ford
Biondo electric shifter solenoid spring type
Carbon dragster scoop insert. Dominator
Aluminum intake GM 458520
Frameworks pro dragster shifter no cable
3.90 gear Ford pro gear big pinion 3 runs.
MSD Cranktrigger dist. Chevy slip collar fits stock - 10.2 deck
Simpson -15 suit 2010 date 1 run size large. Team Jegs jacket black pants
Simpson -5 suit same as -15. Large team Jegs
Oakley gloves 3.3/5 team Jegs Small
Simpson low cut shoes size 9 black. Like new
Impact neck braces black. 1 new 1 used.
Hybrid Pro Rage head and neck restraint. With sliding tether add on.
Impact Champ Alcohol helmet with built in sock and sealed shield. 1 run perfect. Silver size is same as large will get exact.
TWO used crank trigger pick ups
Contact VERNONMCKAGUE@HOTMAIL.COM
573-680-0428
I am going to sell all so don't be shy. All I can say is no
TD561 is offline   Reply With Quote
Old 08-22-2011, 09:21 AM   #2
DIAPERMAN
Liked 21 Times in 6 Posts
Default Re: Garage Sale
will you be at Bowling Green or Indy
DIAPERMAN is offline   Reply With Quote
