Old 08-18-2011, 10:50 AM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Moving springs inboard ihra stock
IHRA stats "Minor movement inboard of rear springs is allowed for tire clearance." Can the 3" inboard movement of the typical Mopar spring relocation kit qualify as "minor movement " for stock eliminator? Thanks
House of Darts is offline   Reply With Quote
Old 08-18-2011, 02:04 PM   #2
treessavoy
Liked 4 Times in 4 Posts
Default Re: Moving springs inboard ihra stock
I doubt that they will accept that much movement. They had the same rule in the AHRA and the only movement they allowed was just enough to clear the tire. I was allowed to move mine in about 1/2 an inch but no more.
Call them up and ask before you make any changes.
JimR
Jim Rountree
Old 08-18-2011, 02:09 PM   #3
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs up Re: Moving springs inboard ihra stock
No......Just enough to clear the side wall of the slicks that you use. Jim is correct.
Old 08-18-2011, 02:12 PM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Every one I have seen done is with the Mopar kit. Just dont go all the way
Bob Pagano A/SA
Old 08-18-2011, 07:23 PM   #5
House of Darts
Since IHRA allows a 10" slick for Stock the 3" inset gives the A body the space it needs.
Old 08-18-2011, 08:22 PM   #6
Lambertcars
Page 49 of the IHRA Rule Book under Suspension states minor movement inboard of rear springs is allowed for tire clearance. I think that 3 in.on both sides is more than minor. What is the NHRA rule?
ALLEN
Lambertcars is offline   Reply With Quote
Old 08-18-2011, 10:12 PM   #7
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
If your gonna move it enough for a 10-10.5 inch tire, you will be into the frame section. If you move it one inch or three inches, it still requires the same amount of work. Also the same areas and components to be modified plus a half of a tub. ONLY ALLOWED IN CRATE MOTOR STOCK. I believe the intent is to allow you to put a 10-10.5 tire under the car properly and safely. And to do that you should have 13-14 inches of clean tire area. A Duster has about 14 inches give or take, from the quarter panel (wheel opening lip) to the frame flange (spot welded to the floor) and you will need it all to do it properly. Then you will need about a 2 inch extension to the wheel tub. The rule book says minor inward movement (how much is that) to me it's the minimum it takes needed for a 10 inch tire to have the safe tire/body clearence and no more. They said you could move it, and they said you could use a 10 inch tire. Do what you need to make that happen and no more. Having said all of that, the best way to do this is send photos to IHRA TECH DEPT. (Hank or Mike) of what you want to do and why...present your case, and you will be fine.
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 08-19-2011, 10:33 AM   #8
Harry 6674
ALLEN
NHRA is zero.
Harry 6674 is offline   Reply With Quote
