Old 08-07-2011, 11:14 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 3919840 & 3919842 Square Port Heads, L89 & L78 Blocks
3919840 Heads
F-17-8 & F-18-8 rebuilt $1500
J-31-8 set cleaned and magged bare $1250
J-31-8 & K-4-8 cleaned and magged slightly ported on exhaust side only $1100
C-25-9 set cleaned and magged bare set $1250
3919842 Aluminum Heads
6-15-67 (hairline crack at corner) & 10-9-67 (milled) $1500
10-24-68 & 6-2-69 rebuilt $3500
396 4 bolt L78 #3935440 standard bore E-21-8 T0524MQ 18N449843 $1250
396 4 bolt L89 #3955272 standard bore J-7-8 T1014JJ 19N532943 $3000
396 4 bolt L89 #3955272 30 over J-14-8 T0527KG 19B400425 $3000
6223 steel crankshaft 10 on mains 20 on rods ready to go $300
8 inch timing cover with teeth design timing tab $100
330-770-2517 and can ship parts if you cannot pick up. Can provide pictures if needed.
dlv4540 is offline   Reply With Quote
