Old 08-03-2011, 03:58 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Wanted: Holley Cam Type Base Plate & driver inlet bowls
Looking for parts for 4584-S Holley. This is mechanical secondary yet not a double pumper. Baseplate has 1 9/16" throttle bores front & rear, cam style mechanical linkage. Similar to the style used on a 660 center squirt which has a 1 11/16" throttle bore. Will look at anything you have, will take one or two if you have them.
Also need cathedral bowls with fuel inlet on passenger side. Same carb so the front bowl has accelerator pump and rear has no accelerator pump. Do not want Dominator bowls.
Do you have a complete carb?
Please email me: JeffLeeAZRealty@gmail.com or call 602-418-9797
Jeff Lee 7494 D/S '70 AMX
