Liked 130 Times in 20 Posts
For Sale:
Advanced clutches metal cover dual disc 7" clutch. This clutch is super light and was used this clutch on a 283 sb chevy with 153 tooth flywheel. This clutch has less than 20 runs on it since new and is in great condition. Included with this clutch is the complete clutch set up, throw out bearing and instructions. This clutch fits in a stock depth bell housing. $2400 obo description from www.advancedclutches.com THE SPORTSMAN DUAL 7" – NEW PRO-STOCK TYPE TECHNOLOGY Now you can get pro-stock type technology with this highly tuneable, super light clutch. This clutch can get as light as 18-20 pounds, depending on the make and model of your vehicle. You can adjust the base pressure through the bellhousing. Available for stock, superstock, and street hot rods, this new clutch technology is adjustable, with a light weight design, and longer life of the discs. These clutches are very consistent. Tires: 1 pair Mickey Thompson tires 3072 slicks 31.0/13.0-15 98" rollout 100 runs Lots of tread left $100.00 1 pair Mickey Thompson tires 3009 front runners 27.5/4.5-15 great tread left probably not 1/2 used just changed tire size $100.00 Package deal for fronts and rears $150.00 1 pair tubes for front runner tires (not used on above set) $25.00 parts are near Grand Rapids, MI and can be delivered to Columbus July 22-24 or Mid Michigan Motorplex July 30-31 brad@zaskowskibuilders.com (616)437-4958 Thanks!
Brad Zaskowski 3697 STK, SS |
