Old 07-04-2011, 09:44 PM   #1
hotrods1795
Liked 2 Times in 2 Posts
Default Painless Wiring System
I bought a 69 Barracuda that came with a painless wiring system and it had a tach in it with 3 wires. The tach I'm putting in has 4 wires and is an Autometer Carbon Fiber with a shift light. I know one wire goes to the lights, one to the ground and one to a 12 volt source. Where does the other wire go? Could someone help me to get this tach to work. There is also a 6AL MSD and blaster coil.
Thanks
hotrods1795 is offline   Reply With Quote
Old 07-04-2011, 09:55 PM   #2
Doug Blackley
Doug Blackley's Avatar
Default Re: Painless Wiring System
The green wire goes to the terminal on the side of the MSD box.
Doug Blackley 1697 STK
Old 07-05-2011, 09:05 PM   #3
hotrods1795
Thanks
Old 07-05-2011, 09:27 PM   #4
Mark Madison
Liked 32 Times in 9 Posts
Green = MSD or coil
White = Dash lights
Red = 12v switched Ignition
Black = Ground
Blue = Clutch switch or line lock
Mark Madison
Mark Madison is offline   Reply With Quote
Old 07-06-2011, 09:21 PM   #5
hotrods1795
thanks for the info
