Old 06-28-2011, 09:43 PM   #1
1752supgas
1752supgas's Avatar
Default comp cams bbc roller cam
Serial # H 9714-06 Spec Card# 10168606
Part # 11-000-9 CAMSHAFT, CB SPECIAL ROLLER
Core C11-9P CAMSHAFT BLANK, CB CHEVY 396-454 5160
Grind # CB 1828B /1287B R 110.0
DURATION @ .050 INTAKE 281 ROCKER ARM RATIO
VALVE ADJ INTAKE .024 DURATION @ .050 EXHAUST 294 INTAKE 1.70
VALVE ADJ EXHAUST .028 LOBE LIFT INTAKE .4850 EXHAUST 1.70
VALVE LIFT INTAKE .824 LOBE LIFT EXHAUST .4620
VALVE LIFT EXHAUST .785 LOBE SEPARATION 110.0
DURATION .020 INTAKE C/L 106.0
TAPPET LIFT INTAKE 314 CAM ADVANCE 4
TAPPET LIFT EXHAUST 335 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 34 JOURNAL DIAMETER STD 1.948
VALVE OPEN EXHAUST 81 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 66 DEPARTMENT P
VALVE CLOSED EXHAUST 33 SPC INSTR FOR CUSTOMER
JENSEN'S ENGINE TECH , JUST REMOVED FROM MY 565 , VERY GOOD CONDITION $150 CALL 856 371 8298
1752supgas is offline   Reply With Quote
